hi, im after some dvdr's that i can rely on, ive been using datawrite 4x yellows and ive been told they are poo.
so, i need some high quality ones but not sure what to have....i usually get my stash from http://www.blankdiscshop.co.uk/ so it would be nice if i could still get them from there coz they are cheap, but its not mandatory.
im lookin for 25 packs ranging from £10-£20. any ideas peeps.
oh, btw, im using a pioneer dvd-106d (4X)
Results 1 to 11 of 11
just buy ritek dvd's datasafe ones are very good just make dure the dye is ritekG04
I'm using the same burner, the same media and the same supplier, and have not had a single problem with them. I have never had a compatibility issue with MANY other standalone players either.
The price is right (£10ish for 25), and as far as I can tell reading forums these discs seem very compatible with many burners/players. If they are working for you, why change?
I would, however suggest staying away from the Datawrite Red discs they sell, as I had lead out/burn errors on 1/4 of a spindle. For the extra £3, I am now back to only using the Yellow Classics. -
i have been having a problem with writing dvd movies, but i dont know if its a media problem or a hardware problem, so i was gonna try using a different media.
https://www.videohelp.com/forum/viewtopic.php?t=214938 -
Hmm, I've just checked the website, and noticed the special offer on the Yellow Classics. If I remember correctly, the description is different now also. I have no idea if this means a different manufacturing process/dye than previously, but I shall order a spindle anyway to check.
As I said, so far I have had no problems with these discs, so I hope this continues. -
{DV 3071/25} Ritek Inkjet Printable A Grade 4x DVD-R in pack of 25
All the time for me
Used plenty now not one coster that wasnt MY fault.....
I use a Pioneer 105/A05.Not bothered by small problems...
Spend a night alone with a mosquito -
if your burning dvd movies 1-1 copy's your better useing ritek dye dvd media as most home dvd players can play them
any only ever really use them for writing dvd-5 or converting dvd-9 to dvd-5
high quality playback on dvd players is a must. -
Originally Posted by iooi
And in response to this, Will Hay says...
All the time for me
I use a Pioneer A07.tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
I do! I have many different projects I burn onto DVDR, should it be a car rally or a show captured off TV. DVD copies account for less than half of my burns!Originally Posted by Rud
As for which disc, I always use the frosted-topped Riteks (last batch were £15 for 25) as I have the TDK thermal printer and it doesn't like white topped printables. -
i buy the Ritek overprints (the orange ones- NOT the grade B "landscape stuff!!!!) and burn them at 8x (they are rated 4x) with my Pioneer 107D.
i have had no coatser or anything and they are £11.50 for 25!!!!!! amazin deal!!!1)Why Not Overclock a little?! speed 4 free!!!!
2) If your question has anything to do with copying PS2/PC/XBox games, find a more appropriate website
[url]www.youconvertit.com[/url] will convert most files
By Topp in forum Video ConversionReplies: 12Last Post: 21st Feb 2009, 18:58 -
Trouble with avidemux and [url]www.debian-multimedia.org[/url]
By Verlager in forum LinuxReplies: 24Last Post: 1st Dec 2008, 23:27 -
is it just me or has [url]http://www.rpc1.org/[/url] been awol for awhile?
By aedipuss in forum DVD & Blu-ray WritersReplies: 11Last Post: 31st Dec 2007, 00:19 -
Just found this on [url]www.blankmedia.ca[/url]
By SilverBlade in forum MediaReplies: 0Last Post: 13th Sep 2007, 22:41
